It is currently Mon Aug 03, 2026 8:23 am
PostPosted: Sun Jul 20, 2008 5:54 pm
I have to replace the front port corner casting on my hobie 16.If anyone has some insight into this give me some heads up please.Some initial questions I have are as follows.
Should I tighten the dolphin striker nut before or after putting in rivits?
How important is it to have boat level when putting back together?
Any suggestions on a marine sealent to put in castings to reduce squeaking.
Does the casting come with bolt hole already drilled?
PostPosted: Mon Jul 21, 2008 3:10 pm
The bolt hole may have to be drilled. The castings are drilled for the smaller / current bolt size.
Grease the pylon.
Tighten the striker after fully assembling and riveting.
Level boat would be good before drilling the pylon bolt hole.
PostPosted: Mon Jul 21, 2008 3:44 pm
Thanks Matt,my boat is a 2006 so it would have the smaller bolt hole.Is there any set # of turns to put on the dolphin striker nut?
