It is currently Mon Aug 03, 2026 7:07 am
PostPosted: Tue Aug 19, 2008 4:14 am
Every time i have set up my H16 its been on the launch except stepping the mast, that i do while its on the trlr. My question is has anyone ever done a setup 100% on the trlr? What would be the up and down sides of this. The reason i ask is simply because my 10year old had asked me that question and i really didnt have a answer for him. Where i put in its not really a good thing for me to do that i have to go around a few tree branches above the launch and i dont want to take the chance on ruining my sails. I told him i would try to get him a answer on what other people thought on setting up on the trlr. Thanks again.
Mark
1989 Hobie 16
Sail # 92778
PostPosted: Tue Aug 19, 2008 6:16 am
Only reason I ever completely set up on the trailer (minus raising sails) was when having to launch from boat ramp due to no beaching spot.
PostPosted: Tue Aug 19, 2008 6:18 am
I would say that towing any boat on a trailer with the sails up would be a very bad idea. If there is any breeze, that would make it even worse.
When you set your sails and there is a breeze, you want to have the boat pointed into the wind.
Sail Like you Have a Pair
Bluish gray 73 - 83 H16
Super Nice Yellow 84 H18
PostPosted: Wed Aug 20, 2008 11:13 am
Not a problem setting it up on the trailer. Make sure you don't take all of the tie downs off or you will end up with the nose or the stern on the parking lot. If you put the sail up also make sure at least 2 tie downs are still attached and the sails not cleated so you don't blow off of the trailer. Once started backing down the ramp the tie downs can come off and once in the water hold the boat into the wind before boarding and sailing off
Brooks
