It is currently Mon Aug 03, 2026 8:16 am
 Post subject: dolphin striker tension
PostPosted: Fri Aug 22, 2008 7:38 pm
I sail alone alot, off a small beach, and at the end of the day, have to pull the boat up 15-20 feet above the tide line- not eniough for cat tracks, but find that I end up pulling the boat, holding the dolphin striker, and it feels loose,, i.e, it pulls forward a little when I grab it. Is there a way or a standard to test how tight it should be? Or am I worried about nothing?
Raced extensively as a kid (against Matt Bounds!!), just bought a 20 year old 16 and am refurbishing it.
Sail # 21888
PostPosted: Sun Aug 24, 2008 8:23 pm
I believe that Hobie recommends that the dolphin striker not have any give. I don't know the torque spec, but I have seen a hull collapse at the front crossbar due to it being loose.
PostPosted: Mon Aug 25, 2008 2:08 pm
If the beach you sail off of is your own property, try sinking a post into the ground and putting a winch on it. Then fashion a bridle that can easily be attached to your two forward pylons.
Takes a load off of your back as well
PostPosted: Fri Aug 29, 2008 12:31 pm
Rock,
Tighten the dolphin striker until it makes a "thummmm" sound when you hit it with the palm of your hand.
If it's not tight enough, it'll go "thunk".
PostPosted: Sat Aug 30, 2008 8:26 pm
Matt, that is the "field test" I was looking for! The nuts don;t appear to have backed off, but it definitely feeels looser than on Monster Fish. ( My old race boat)
Thanks so much-
Rock
Sail # 21888
