It is currently Mon Aug 03, 2026 5:00 am
PostPosted: Sat Aug 23, 2008 11:32 am
How much does a steel trailer for a hobie 16 weigh? Just want to know if my car can tow it.
CP
PostPosted: Sat Aug 23, 2008 12:15 pm
Depends on the construction. But 300 - 350 lbs is a good estimate.
PostPosted: Sat Aug 23, 2008 12:20 pm
Thanks.
PostPosted: Mon Aug 25, 2008 5:56 am
If you're on the edge of whether your car can tow it (i.e. a small 4 cylinder), you might want to do a weight check with a bathroom scale. Is it an aluminum or steel trailer? My trailer is a farily heavy steel channel and I'm pretty sure it weights more in the 500 to 600lb range (it is quite sturdy though). Unless you've got a really beefy trailer, the boat and trailer will probably weigh 1000lb or less, which is within most vehicle's towing capacity.
If in doubt, record the weight reading under each wheel as well as under the tongue, add them all together, and you'll have the total weight.
