It is currently Mon Aug 03, 2026 8:38 am
 Post subject: Trapeze wires
PostPosted: Tue Apr 28, 2009 8:32 am
Hi, should one trap wire be longer than the other .The one wire has a pigtail that is about 12" long than a thimble on the end connected to the other trap wire with a shackle.Is this normal .I'am tring to post a picture of it but i can't figure out how.
The Waters always there,just wanting some good wind.
 Post subject: Re: Trapeze wires
PostPosted: Tue Apr 28, 2009 9:19 am
The wire with a pig tail is a very early system for getting double trapeze on an older mast with single shackle. The second trap wire should be shorter so the two match at the handle point. If you have a newer wire... you should just hang next to the one with the pigtail rather than on the pigtail.
Image FAQ: http://www.hobiecat.com/community/viewtopic.php?f=18&t=8574
PostPosted: Tue Apr 28, 2009 9:37 am
Thank you that makes sense now i thought it was someones weird rigging.Thanks again Brad.
