It is currently Mon Aug 03, 2026 3:41 pm
PostPosted: Tue Sep 08, 2009 9:53 am
Any tips on removing bow tang nut/bolt to install new bridle wires? Boat is an 86 model and bridle wires are in need of new ones of course. It's hard to get a full seat on nut with socket without chipping some gelcoat in order to do so. Also it's difficult to hold a bite with a common screwdriver on the bolt head.
I hope someone can give me a couple tips to make this task maybe a little easier!
Another thought, wouldn't a hex head bolt be easier to deal with in the future than a panhead screwdriver applied type?
Thanx ahead for any suggestions here.
UK Wildcats have 8 now!
1976 H16 27640
1985 H16 89112
PostPosted: Tue Sep 08, 2009 12:24 pm
Try Vise Grips on the nut.
Hex heads have sharp edges. The nut does not require significant tensioning, so the slot / pan head works.
PostPosted: Tue Sep 08, 2009 3:53 pm
Yeah they are a bear to get off if your boat has spent any time in salt water. I had to use an impact driver (not recommended) so I replaced mine with hex bolts when I finally freed them up. I use hex bolts on the crossbar end adjusters and rudder arm slide plates too for the same reason. You just can't get enough torque with a screwdriver on a salt water seized bolt or screw. I'm not sure the edges on a hex bolt are going to be any more dangerous than anything else. Everything on the boat that I land on, am thrown against or bounce off of hurts anyway. :lol: What's one more bolt?
PostPosted: Tue Sep 08, 2009 4:04 pm
PB blaster?
PostPosted: Tue Sep 08, 2009 4:47 pm
Fixin to attack it again. Thanks for suggestions. PB is most definitely a must!
1976 H16 27640
1985 H16 89112
PostPosted: Tue Sep 08, 2009 5:08 pm
If it won't come loose, then cut the head off with a Dremel tool.
You weren't planning to re-use it after all the abuse you're giving it, were you?
PostPosted: Tue Sep 08, 2009 5:30 pm
I honestly believe that's the easy and smart approach. No, I wasn't intending to reuse regardless of possibly no battle damage.
Thanks Matt
1976 H16 27640
1985 H16 89112
PostPosted: Tue Sep 08, 2009 6:14 pm
Thanks Matt
Just watch the heat build-up. Wouldn't want to start a fire or anything like that. :shock:
