It is currently Mon Aug 03, 2026 10:47 am
 Post subject: New sheet for the main
PostPosted: Fri Sep 25, 2009 4:12 am
What kind of sheet and length of sheet for the main do you guys recommend for my 1985 H16 that I just bought?
I got her home and noticed that the blocks were missing from the traveler so I called the guy up and he found it out in his garage and I went and picked it up. The actual sheet is missing from the traveler though.
Any special recommendations?
Thanks in advance,
Maury
“Smooth seas do not make skillful sailors.”
PostPosted: Fri Sep 25, 2009 5:27 am
Authorized Hobie Dealer
current boats get 44' of 5/16 line. Older boats came with 3/8 line Call you dealer and get some on the way so you can go sailing!
Brad Stephens
http://www.sunjammers.com
www.facebook.com/sunjammers
PostPosted: Fri Sep 25, 2009 6:23 am
Thanks Sunjammers,
This is an 85. So I assume that I would use 3/8. Right?
Best Regards,
Maury
PostPosted: Fri Sep 25, 2009 8:21 am
it depends on the blocks, 3/8 will work on all of them but the 5/16 runs thru the blocks better
Brad Stephens
