It is currently Mon Aug 03, 2026 1:07 pm
 Post subject: Wet Suit
PostPosted: Sat Jan 30, 2010 8:09 am
Went sailing in the intercoastal the other day. Water temp around 60, as was the air temp. I tried a wet suit for the first time while sailing. It was a little confining at first but it kept me amazingly warm and comfortable, even with alot of spray and wind. The cold has become less of a factor when deciding to go out or not. I bought the wet suit at a thrift store for $10!
Mims, FL
 Post subject: Re: Wet Suit
PostPosted: Sat Jan 30, 2010 10:55 am
Proper fit is everything when it comes to being comfortable in a wetsuit. It's essential that you try the suit on before you buy it (or, if ordering online, be sure to ask about the seller's exchange policy). A suit that's too loose will allow for water exchange which means it won't keep you as warm as it should. A suit that's too tight will constrict your movement which will cause you to tire quickly and be very uncomfortable.
I hope you washed that thrift store wetsuit well before using it. It's one thing to wear a suit that you've pee'd in. It's quite another thing to wear a suit that someone else has pee'd in... :?
PostPosted: Sat Jan 30, 2010 9:28 pm
Yes its extremly important to not have someone elses pee residue in your suit, Absolutley deadly. And for goodness sake be careful of that dreaded ocean water. :lol:
http://s909.photobucket.com/albums/ac294/gsammy925/
PostPosted: Wed Feb 03, 2010 3:29 am
Well then, it's just a matter of time for me.... I didn't wash suit at all. Guess I'll not be buying any green bananas!
Mims, FL
