It is currently Tue Aug 04, 2026 1:05 am
PostPosted: Tue Apr 13, 2010 5:10 pm
I have been using a razor but the going is slow and a lot of dirty sticky gunk is still left on the surface. Does anyone know what might make this easier?
1977 Super Sunfish (sold)
1979 Hobie (sold)
2008 Hobie 16 (sold)
2023 Hobie 16
John
PostPosted: Tue Apr 13, 2010 5:36 pm
http://www.harborfreight.com/cpi/ctaf/d ... mber=65057
Try this. It's a hot blade decal remover. It will do a pretty good job. You could also use a heat gun and a razor scraper but there will be less gouging of your gelcoat if you use the tool linked above. Sill going to need a solvent specific to the tape adhesive to remove the gunk. Acetone usually does it.
PostPosted: Tue Apr 13, 2010 6:41 pm
I don't like using a razor to remove the stripes because of the gouging problem.
Nasty solvents, a plastic scraper and lots of time.
(nasty solvents and heat guns do not mix)
PostPosted: Tue Apr 13, 2010 9:19 pm
try a hair dryer.. peel slow.... and then solvent (GOOF OFF) to remove the sticky gunk....
•Present boat -1998 Hobie 16 Solana Sails furling jib[/size]
PostPosted: Wed Apr 14, 2010 10:32 am
rubbing alchol gets the residue off as well...i just rubbed it on the stripes and went at it with a razor on my 14t and it came off perfectly
1981 Hobie 16
1982 Hobie 14 turbo (sold)
1996 SeaDoo GTI
1999 Hunter 340
PostPosted: Fri Apr 16, 2010 6:09 pm
Warning, if you peel the stripes off of hulls that old, the gel coat under the stripe will be whiter, for years and years.
PostPosted: Sun May 09, 2010 9:25 pm
Sometimes a powerwasher will take them off. You will need to use fiberglass polish (works like a wax) to shine them up afterwards. I am debating doing this on one of my boats due to the problem mentioned above (lighter colored hull under the stripes).
PostPosted: Mon May 10, 2010 10:47 am
I just did this on a yellow '81 H16.
I used a heat gun from Harbor Freight (not the one linked above, this one instead: http://www.harborfreight.com/1500-watt- ... 96289.html). Once you get the right technique it will take most of it off.
Then I used goof off which worked great.
The color differential was actually not that bad, and now I kind of like it. After I polished my hulls (with this: http://www.westmarine.com/webapp/wcs/st ... sNum=10387) the color was much closer, close enough to live with anyway. Pound for pound it was definitely worth it that's for sure, considering the effort I put in and the result I got.
Good luck!
'81 H16
PostPosted: Wed May 12, 2010 10:44 am
+ 1 on a real Heat Gun for removing stripes or stickers
then use Acetone to remove the glue residue. Douche well with Acetone and rub lightly in a circular motion. Glue balls up and comes right off.
Bill's right on the color diff...not so noticable on a white boat, really noticable on a yellow or blue boat. You may consider stripes back in the original location, but especially annoying are the locations of the old registration numbers. :roll:
Sheet In...Max Out
www.fleet297.org
