It is currently Sun Aug 02, 2026 4:45 am
 Post subject: Fast shackles on the jib
PostPosted: Mon Jun 27, 2005 9:27 am
I just bought a few fast shackles for my jib, and another sailor mentioned that they might not have the same strength as the regular shackles. Any thoughts?
Craig
 Post subject: Shackles?
PostPosted: Mon Jun 27, 2005 1:59 pm
The breaking strength should be loisted in any sales information on them. If for standing rigging (holding up the mast) you should be most cautious.
 Post subject: Quick Pins
PostPosted: Fri Jul 08, 2005 11:36 am
I've used Quick Pins for my jib for years and they have always worked great. You should be sure to maintain them though. I will spray them with WD-40 at the beginning and end of the sailing season. (Winter in Michigan)....plus take extra time if you are sailing in saltwater or if the pin falls in the sand.
PostPosted: Wed Jul 13, 2005 7:30 am
I checked with the manufacturer and the sheer load was higher than the standard shackles.
As long as the pin stays in they should work great, and are so much easier to use with my big fingers...
Craig
 Post subject: Quick pins
PostPosted: Thu Aug 18, 2005 11:57 pm
Hey Craig
If you have not and can put a lanyard one the pin definitely do it. I had one come out on me. Fortunately it was on a leash!
Mike
PostPosted: Sun Sep 25, 2005 6:18 pm
in my experience the best type of shackle to use in most situations on a sailboat is a captive shackle, that is one which the pin will not fall out of even while open, this is a big help while in a hurry to rig, saving many trips back and fourth to the nearest source of shackles. they are also much faster to open and close and because they snap shut they are less likely to be shaken open by vibrations and whatnot and i have never seenone break when used properly.
The pessimist complains about the wind, the optimist expects it to change, the realist adjusts the sails.
