It is currently Sun Aug 02, 2026 3:19 am
PostPosted: Tue Oct 18, 2005 7:36 am
Hmm I have no problem in reading my jib telltales, where i can yell at my crew to sheet in or sheet out, plus i know when im on the beat, that if the sail is as sheeted in as it gets, and the inside one is flapping, im pinching...
BUT!
I dont know how to read my mainsail tell-tales! some help please!:)
 Post subject: Tell Tails
PostPosted: Tue Oct 18, 2005 10:35 am
"what exactly do the telltales do for you? and how do you read them?"
They make the air flow over the sails visable. The tell tails will follow the direction of flow. You want the flow running generally fore to aft. If the air flow is disturbed, you can see it in the tell tails.
You can make adjustments in helm and or sail to correct the flow for best performance.
Basic adjustments are:
Leech tails in the upper third help avoid hooking the leech to weather from over sheeting. You want the upper leech tails to tuck / fly / tuck etc. alternating.
If they are tucking to the lee side all the time, the leech is hooked to weather, sheet out. If they are flying all the time, you are under sheeted, sheet in.
Light air... sheet out a bit to open the leech. Travel more to center and sheet out a little.
Downhaul causes the leech to open, so downhauling less and sheeting harder should get the leech tighter and make the tails tuck / fly / tuck more.
It is mostly a balance of sheet, traveler and downhaul... but mast bend and rotation some too.
PostPosted: Tue Oct 18, 2005 10:50 am
thanks for that,
but i find that that works perfectly well for my jib, and i can see the change immediately....
whilst on the main sheet, i dont see the real changes happening...a lot of guys have told me, dont bother with reading the telltales on the main sheet....
I dont know...do they tell me a lot? and how do i work on particular parts of the sail? for example the bottom telltales tend to move around perfectly..but the others will be flapping like mad?
do i just ignore, or am i doing something wrong here?
 Post subject: Main Tell Tails
PostPosted: Tue Oct 18, 2005 11:53 am
Main Tell Tails can help you adjust traveler position and major sheet adjustments. Use the leech tails described above for the fine tuning and pretty much ignore the main tails at that point.
