It is currently Sat Jun 20, 2026 8:10 am
 Post subject: Hobie 16 Rudders
PostPosted: Sat Jun 26, 2010 6:33 am
Anyone know how to clean up rudders? The stock rudders discolor and can't afford the EPO's. Thanks.
 Post subject: Re: Hobie 16 Rudders
PostPosted: Mon Jun 28, 2010 6:53 pm
Toilet bowl cleaner
the hull cleaner stuff they sell in the Hobie catalogue
never tried it on all the different "non-fiberglass" rudders but...
a fresh cut lemon wedge (rubbed directly) works on white glass rudders
Sheet In...Max Out
www.fleet297.org
PostPosted: Mon Jun 28, 2010 7:34 pm
Plastic rudders should lokk like brand new if you'll wet-sand em' with some 600 grit wet/dry sandpaper.... Just did my 86' EPO's and sprayed em with appliance gloss-black and they look awesome!
PostPosted: Tue Jun 29, 2010 4:52 am
Anything with oxalic acid as it's main active ingredient:
Barkeeper's Friend
Zud
OxyClean
etc.
PostPosted: Tue Jun 29, 2010 6:47 am
Else just wet sand them down. I'm assuming they are the old lexan white rudders.
PostPosted: Tue Jun 29, 2010 6:58 am
I just refinished my fiberglass rudders this past weekend. I used mineral spirits to clean them, sanded them down, cleaned them again, then used automotive spray paint to put 3 coats on each side. It worked very well. They were all yellow and nasty, now they are a nice bright white.
1979 Hobie 16
PostPosted: Tue Jun 29, 2010 8:12 am
Wet sand most definitely! the plastic rudders should look like new after a once over with 220, then a finish of 600.
PostPosted: Tue Jun 29, 2010 9:58 am
There are exceptions to the wet sand recommendation that I and others have made. i am assuming your rudders have an ordinary finish. My recommendation is invalid if your rudders have some kind of high gloss finish i.e. racing rudders or EPO 2 carbon fiber rudders with gucci looks.
PostPosted: Tue Jun 29, 2010 5:08 pm
I have the old lexan rudders which had yellowed. They looked terrible so I sanded them down very well using a medium grit sandpaper. I then cleaned them using Acetone. I purchased a rattle can of semi-gloss black paint made for plastic from Lowes and sprayed several coats on the rudders. They turned out great and after a year of use have hardly a scratch at all. I was very pleased with the results.
'88 Nationals Blue
Hobie Alter Signature Model
Sail #11
Hobie Mirage Classic
