It is currently Sun Aug 02, 2026 6:59 am
PostPosted: Thu Jan 19, 2006 11:10 pm
I know it's not class legal but has anyone here ever used a mast rotation control arm on a H16? If so, what type of mounting brackets were attached to the mast? Would appreciate any info.
David
 Post subject: mast Rotator
PostPosted: Fri Jan 20, 2006 8:56 am
I used a bracket for a boomless shaped like a V I got from Murrays on my Hobie 17. Ran a block system with a cleat to the boom. Works great. If confused call me. 8)
Doug Snell
281-326-2702
PostPosted: Fri Jan 20, 2006 9:31 am
Thanks for the input Doug. I have found the rotation arm that you were referring to at Murray's. What I need is the two mounting brackets that are riveted to each side of the mast that rotation arm is connected to. I think mast on your 17 might already come with the brackets on it. Any ideas ?
David
 Post subject: Brackets
PostPosted: Fri Jan 20, 2006 9:41 am
I just took off my old arm and bolted new one on. Call Murrays on there 800 number. They have always been VERY helpful to me. If they don't have them, I am sure they can send you in right direction. Good luck.
Doug
PostPosted: Fri Jan 20, 2006 10:29 am
Thanks again Doug,
Does the bolt go all the way through the mast ??
 Post subject: Bolt
PostPosted: Fri Jan 20, 2006 10:39 am
David:
Yes, just like all the mast rotator arm do. Murrays should help you. Steve has always be great to me. Good luck. I stared on a 16. good boat, just got tired of always fighting to find a crew. Hope to get a Nacra A2 soon. Good A class fleet around here at Houston Yacht Club. Register and go on our site. www.tcdyc.com. Good forum.
Doug
PostPosted: Fri Jan 20, 2006 11:21 am
It would eb a good idea to spport the inside walls of the mast where the bolt passes though. Either put a tube between the sides of the mast or get a fully threaded bolt and put a nylock nut on both of the inside walls.
Nick
Current Boat
In the market
Previous boats owned
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
