It is currently Sun Aug 02, 2026 10:58 pm
 Post subject: mast base broken
PostPosted: Tue Mar 07, 2006 8:23 am
my h16 mast base had two rivets and both pulled out of the mast base. so i'm thinking the easiest and cheapest fix is to drill 3 or 4 new holes and re installing with aluminum rivets. the reason being that the aluminum would be the weak link and break , hopefully instead of the stainless rivets holding and breaking the base in another spot. anyone ideas on this?
PostPosted: Tue Mar 07, 2006 10:20 am
I had the same problem on my old H16. I re-rivited the same holes and added one more. I used Al rivits because the loads seen on the mast base are all compressive and the rivits don't see much of them. They are there mainly to keep the mast base from falling out. I found that a rivit placed at the very front of the mast base is helpful for extending the life of this repiar.
Nick
Current Boat
In the market
Previous boats owned
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
 Post subject: Aluminum rivets?
PostPosted: Tue Mar 07, 2006 10:27 am
Aluminum rivets are not advised. They will hold fine when rigged, but can easily fail when stepping the mast. That can be devestating.
PostPosted: Tue Mar 07, 2006 10:59 am
Good point Matt. There are some interesting forces on the mast base while stepping.
Nick
Current Boat
In the market
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
