It is currently Fri Jun 19, 2026 10:47 pm
PostPosted: Sat Sep 11, 2010 11:02 am
I'm about to order some stuff. (I have 2 16's) and just picked up another for 175.00!
I want a new harness, but what one? I see skippers, and one like it with detacthable shoulder straps, and then the big one with lumbar.
I'm older - (53) so I like comfort... but I'm on a small lake (about 75 acres) and one length doesn't last very long before I have to get off the wire and swap sides and get back on.
(so lots of OFF AND ON - short runs). Recommendations?
I have 2 of them, but OLD and really quite small for us.
Also thinking of getting a mama or baby bob? Is there any difference? I like the smaller size (looks wise) and price... but I'm hoping to keep the mast tip up to ease recovery. Seems the tip is always underwater - water on sails and I often stick the mast tip into lilly pads. Hoping to keep it up a bit. (turtling not really a issue since our lake isn't deep enough to turtle (7 ft maybe?) at best. Suggestions again?
Thanks for sharing your expertise! in advance.
PostPosted: Sat Sep 11, 2010 5:51 pm
first question, how is your back. skipper harness is good if you have a good back. convertible harness if you have a bad back, more support. if you will be sharing it with other crew people , i would recommend a convertible, because you can adapt it to different uses. Ive used a half or skippers harness for twenty years and recently upped to a convertible for support. HAVE FUN ON THE WIRE, the view is great from out there.
PostPosted: Sat Sep 11, 2010 6:59 pm
Rojoyinc - Small lake; Short tacks-You don't need an expensive harness with straps and lumbar support. Also, you live in Grand Rapid, MI = short sailing season.If you want comfort get a crotchless harness with spreader bar.
I don't know much about mamma or baby bobs, but I'd certainly get something that works well if I sailed on a 7 ft. deep lake with lilly pads. I've turtled my boat several times and that wasn't so bad. I've gotten the mast stuck in the mud twice in a shallow lake and that was awful!
PostPosted: Tue Sep 14, 2010 6:52 pm
The "Mama Bob" is probably overkill for a H16. The "Baby Bob" will keep your mast above water. The "Mama Bob" also weighs more which will make it harder to upright after a capsize.
Although you don't have to worry about going full turtle in a shallow lake, you are more likely to drive your bows into the bottom during a pitchpole which puts alot of stress on the pylon/hull interface.
Tim
84 H16
82 H16
87 H14T
Tortola Sails: 115222
Blue Prism Sails: 88863
Clearwater, FL
