It is currently Sun Aug 02, 2026 5:30 am
PostPosted: Mon Mar 27, 2006 7:20 pm
When you install the access port, do you cut all the way thru both layers of glass ? Has anyone tried using the expandable foam in a can in the soft spots ? How about the type of spray in foam in a bass boat hull ? I thought about scooping/scraping out as much of the softened foam I could reach & spraying in a minimal expanding foam. It gets pretty hard, but its no epoxy.Let me know what you think,,,
PostPosted: Tue Mar 28, 2006 6:25 am
Do a search in the forum on this subject. It has been discussed in extreame detail.
Nick
Current Boat
In the market
Previous boats owned
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
 Post subject: Ports
PostPosted: Tue Mar 28, 2006 8:16 am
When installing ports, you will cut all the way through the fiberglass sandwich. You should be able to see inside your hull. Do not use the spray foam. You must use some type of epoxy or "git rot".
http://www.boatersworld.com/webapp/wcs/ ... ogId=10051
The foam is not a good adhesive and does not penetrate deep into the fibers of the foam and fiberglass. Spray foam will not solve your problem and may make things worse, when you later try and fix it using the correct method.
Good luck,
Danny Galeana
http://pirates.dwebz.net
