It is currently Sat Jun 20, 2026 7:58 am
PostPosted: Thu Oct 21, 2010 8:09 am
Hi
I have a 16 model 2006 (made in USA)
Its the scond time in the last year
My jib lower forsty is broken
Why?
PostPosted: Thu Oct 21, 2010 8:55 am
I don't understand, what block?
I know of no issues with standard equipment failures on a 16. Maybe a photo would help?
My first guess would be improper rigging placing an unusual load on a part not intended to carry that load.
PostPosted: Thu Oct 21, 2010 12:02 pm
Hi Matt
Thanks, it was fast...
here is the block, it is attached to the jib with 5mm twisted shakle
PostPosted: Thu Oct 21, 2010 12:36 pm
That does not look like the block used on a stock system. Looks like the standard H083. You use the "Aussie" jib halyard system right? We use the Harken 099 (Hi Load). Although the strap on top looks the same. I have not seen a strap fail like that before.
Harken is pretty good with warranty. Might want to send a photo on an email to them.
Where are you located? Isreal?
PostPosted: Thu Oct 21, 2010 2:56 pm
this was supplied with the boat.
maybe a wrong block?
Ziv
PostPosted: Thu Oct 21, 2010 3:21 pm
Thanks Matt
I will confirm that the new block will be 099 HL
I am from Israel (Sdot yam) we have here a community of cats
(all kinds)
the hobie 16 is well known here as the most reliable one
personally I fly a 16 for 25 years
PostPosted: Fri Oct 22, 2010 8:25 am
Regardless of the H083 or 099... the top strap of stainless is the same. I suspect an unusual wear of some kind. Especially if this has happened twice in a year?
PostPosted: Mon Oct 25, 2010 8:59 am
Matt
I have noticed numerous of failures of H099 in exactly the same manner. All on relatively new boats. I corresponding with Jacques on this issue while you were in China.
Rich
PostPosted: Mon Oct 25, 2010 4:22 pm
I'm checking further to see what Australia has been using on our boats there.
In the meantime... failures of these blocks is a Harken issue. Contact Harken for any warranty issue on them.
PostPosted: Mon Oct 25, 2010 4:28 pm
Australia uses a Ronstan 3011 (RF3011HL) modified a bit. They have the bearings removed and a sleeve inside the sheave. We will be using those in production when we can get them.
