It is currently Sat Jun 20, 2026 9:50 pm
 Post subject: Mast Base Repair
PostPosted: Sun Nov 14, 2010 8:53 am
I have read previous posts on repair/replacement of mast base. I did not note if you should or should not use rivet caps in this application. I have read in this forum that rivet caps should be used any time you penetrate the mast, however this is below the internal mast plug. ?????
Glenn Davies
'81 H-16 Cat Fever/Blue Hulls
'83 H-14 Cat Fever/Blue Hulls
 Post subject: Re: Mast Base Repair
PostPosted: Mon Nov 15, 2010 9:51 am
Caps are not necessary for the mast base. That area of the mast gets wet by design. The mast base does not form a perfect seal to the mast.
Eric Weller
2006 F18 Capricorn
1980 H16
Keep the pointy side up!
