It is currently Sun Aug 02, 2026 1:51 pm
 Post subject: Hull repair advice
PostPosted: Sat Apr 15, 2006 8:30 am
My port side bridle wire has pulled through the bow taking a chunk of fibre glass away. I can get it re-glassed but it seems to me it'll be less than perfect. I've seen another guys boat that has a machined stainless steel bar in a V shape that fits under the gunwale. Someone else suggested bolting a machined stainless steel plate from the tip of the bow to about 10 inches to spread the load. Any advice from you repair gurus woukd be most welcome.
Conor
PostPosted: Thu Apr 27, 2006 11:08 am
Hi from Saudi Arabia,
I had a similar thing happen....I got some Devcon Aluminium 2 part putty and filled in uner the hull lip for 2-3 inces back from the bow.
Before it cured I drilled a hole for the bow tang thru the original hole area and curing putty.
Then I bolted it all together with a 3/16 Ally V shaped plate underneath....as it was tightend the putty was squeezed into the lip and out everywhere, but filed the hull lip completely...just go round with a plastic scraper and clean up.
I did the other hull as well.
It's laster 3 years of abuse.
Nigel
 Post subject: repair advice
PostPosted: Sat Apr 29, 2006 10:00 pm
Thanks Nigel,
I've spoken with other H16 sailors who gave much the same advice.
If you're ever in Dubai on R&R and fancy sailing let me know. There are always boats available at Jebel Ali Sailing Club.
Regards
Conor
PostPosted: Sun Apr 30, 2006 3:39 am
Hi,
Thanks for the invite.
Do you have organized races there in Dubai?
The H16 racing scene here in Saudi and in Bahrain is basically non-existent.
Nigel
PostPosted: Sun Apr 30, 2006 4:29 am
We race most Fridays in Dubai. The fleet is mixed consisting mainly of H 16's, Topcats, F18's, Spitfires, Hobie FX One's, Shadows with some other odds and sods. Last Thursday and Friday we had a cat regatta and managed to get 27 boats on the water for very exciting close quarter sailing in 18kt winds. The club (JASC) has 2 H16's and some monohulls it rents out and most members will be also happy to facilitate guest sailors. There's also a big Laser fleet, a couple of monohull doublehanders and some keelboats as well. Visit the website at www.jebelalisailing.com.
Regards
Conor
