It is currently Sun Aug 02, 2026 7:43 pm
 Post subject: aftermarket kite idea
PostPosted: Wed Apr 19, 2006 2:43 pm
I'm running low on cast and buying an I-14 is looking a bit too expensive so I'm thinking of turbo-ing my Hobie 16 if it doesn't sell. Here's my idea:
I'm going to rig an old windsurfer mast from the dolphin striker to abut 2-3ft past the forestay wire tringle. On the end of this I'm ging to rivet a block for the kite's tack to run through. I'm going to build a bag that will mount under the pole for the kite to get sucked into. Next Im going to rivet a block to the tip of the mast and PRAY hat I can find an old I-14 kite to fit these dimensions. Finally I'm gonna mount some sheet blocks just aft of the shrouds since the kite is gonn be masssssssivve.
So what does everyone think? I know it's not class legal (obviously) but it'll be fast as hell. I may also replace and move the shrouds to deal witht the new fowrd loads. Anybody think that's necessary?
"I'm just tryin' to keep everything in balance, Woodrow. You do more work than you got to, so it's my obligation to do less." Augustus 'Gus' McCrae
PostPosted: Fri Apr 21, 2006 3:22 pm
The only thing I can comment on besides the speed aspect is the fact that submarining the pontoons becomes a much greater risk-- Much higher doward forces, and their bouyancy up front is already suspect before doubling the fore-mast sail area and weight.......
