It is currently Sun Aug 02, 2026 10:25 am
 Post subject: Rolling Jibes
PostPosted: Thu Apr 20, 2006 8:29 am
How do you do a rolling Jibe
when your batons start to snap and the wind is at your back, you see a white cap, and your on a hobie cat, pull in your lines and you see it start to rise
does
your jib hang low
PostPosted: Thu Apr 20, 2006 9:44 am
Put all of the weight forward, jibe hard, and tuck-and-roll 'cause you're going over!
Seriously, I've never heard of a rolling gybe. There's the Roll-Tack technique, and the S-Gybe which is designed to take a lot of the force out of the main coming across - perhaps this is what you mean.
I'm far from a master of the S-Gybe - perhaps someone else could explain it.
Tim
http://www.hobiefleet72.org
 Post subject: ?
PostPosted: Fri Apr 21, 2006 1:41 pm
????? huh?
PostPosted: Wed May 03, 2006 5:46 am
Do you mean like a power gybE? we do it with windsurfs here...a friend of mine went to Turkey for one of those Hobie Holidays, and said the instructor cud do a power gybe on a hobie....NO IDEA how...
 Post subject: huh?
PostPosted: Wed May 03, 2006 9:13 am
Whats a power gybe?
PostPosted: Wed May 03, 2006 10:22 am
Maybe he's talking about a jib furler?
2005 Hobie 16 - Ventura Nationals Boat #21
http://www.JackieandAlan.com
PostPosted: Wed May 03, 2006 11:02 am
ok so here is what im talking about....
i heard this trick from a friend of mine, he said he saw a video
but what you do is while flying a hull gybe into the wind and pretty much one motion pop back up. it appears to be as if you are rolling
anyone seen or heard of such things let me know
does
your jib hang low
PostPosted: Wed May 03, 2006 3:08 pm
anyone seen or heard of such things let me know[/quote]
Ummm. You don't gybe into the wind, I think you are talking about a roll tack here. I have seen these done in A-Cats. Where they will fly the windward hull WAY up, and tack the boat, then slide in off the trapeeze, come under the main and get out on the new windward side,and sheet in and go. Similar to you would tack a laser or other mono-hull. Never seen this done on a 16.
You can also roll gybe a laser, but I don't think you would have any advantages to trying it in a 16.
