It is currently Sun Jun 21, 2026 3:33 am
 Post subject: h16 rudders
PostPosted: Thu Apr 28, 2011 8:02 pm
Where can Iget a rudder template for h16
 Post subject: Re: h16 rudders
PostPosted: Fri Apr 29, 2011 4:00 am
  • at the top of this page, click on "Support"
  • on the left column, under "Product Support", click on "Sailboats"
  • in the "REPAIR" section, click on "Rudders - Cams / Rake / Alignment"
In there, you will find the instructions and also a link to the template.
Marc...
PostPosted: Fri Apr 29, 2011 4:01 am
Contact David Brookes at the IHCA - david.brookes(at)hobieclass.com
PostPosted: Fri Apr 29, 2011 6:05 am
Before you print it make sure you turn off all scaling in your printer properties. It usually says something like "shrink to print" or "fit to page". After you print it measure the two dimensions for accuracy. Also try to find some heavy bond to print it on.
