It is currently Sat Jun 20, 2026 10:42 pm
PostPosted: Tue May 03, 2011 6:32 pm
I am trying to get some pretty intense rust stains from a white sail. I have seen on the forum the suggestion to use West Marine FSR. It seems that that gel woul dbe too caustic to use on a sail. I have tried some rust remover I picked up at Walmart to no avail.
Any suggestions? Or can someone confirm the use of FSR on sails.
Bruce Neill
Sanibel Island, Florida
'82 Hobie 16
PostPosted: Wed May 04, 2011 12:58 pm
I've never been able to remove rust and mold stains from an old sail. I've used the recommended Barkeeper's Friend and even bleach (not together, though since it produces cyanide gas) and never been able to remove the stains. The best it got was the stain was a little lighter.
You are probably going to need to go to sailmaker and get a patch made if it bothers the people you are passing on the water!
Eric Weller
2006 F18 Capricorn
1980 H16
Keep the pointy side up!
PostPosted: Wed May 04, 2011 1:57 pm
Thanks Eric,
I will remember to speed up when passing them, so as not to offend them for too long.
The next logical question is what lugnut wraps a sail around a boom, a block and a hiking stick and doesn't rinse the salt off the sail????
Bruce
Bruce Neill
'82 Hobie 16
PostPosted: Thu May 05, 2011 10:06 am
The sail I got actually had moss growing on it in thick patches. The sail was ruined. The owner fold rolled the sail and stored it in a closed, leaky shed over a summer and never checked on it. Fortunately, I was only borrowing it while my sail was being repaired. It looked so bad even after cleaning and scrubbing, I couldn't force myself to raise it on my boat and waited for my sail to get finished.
Eric Weller
2006 F18 Capricorn
1980 H16
PostPosted: Thu May 05, 2011 11:04 am
Location: Latrobe, PA, USA *** Show YOUR Location - Edit Profile ! ***
I would use a solution of oxalic acid.
Bar Keepers Friend contain it with other ingredients but I would try it alone for a really tough rust stain.
It is a reducing agent and also works by chelating the iron.
It shouldn't affect a dacron sail.
Be aware of its toxic properties though.
You can buy it on eBay.
Raise your sail one foot, and you get ten feet of wind.
起你的一只帆,和你10英尺的。 -- Chinese Proverb
William D. Latinette @ Latrobe, PA, USA w. H14 Turbo X 2... [email protected]
PostPosted: Fri May 06, 2011 3:04 pm
CLR would probably work too.
Marc...
