It is currently Sun Jun 21, 2026 6:01 am
 Post subject: Gin pole for my 16
PostPosted: Mon May 23, 2011 3:09 pm
I made a gin pole so I could raise the mast on my old 16 and have had a question or 2 about it.
Here's a link to a set of pictures I took of it in my side yard today.
Basically it's a 2x4 cut on one end to conform to the mast and the other end has a couple of u-bolts with shackles that connect the forestay and winch cable.
It connects to the mast with a strap clamp and has "anti-sway lines" to keep the mast in line and the pole upright during setup.
https://picasaweb.google.com/108261211615172031808/Hobie16GinPoleFlicks?authkey=Gv1sRgCLXby9moyPjDEA#
Better pictures will follow on a sunny day and away from the house.
Hope this hels someone...
Ed
'76 Hobie 16
 Post subject: Re: Gin pole for my 16
PostPosted: Tue May 24, 2011 7:37 am
Thanks. I've considered making one before. I would not have thought about putting the side supports to avoid swinging sideways.
I don't plan to step the mast more than once a year though as my boat stays on the beach mast up all summer.
Marc...
PostPosted: Tue May 24, 2011 1:05 pm
Lucky dog! I have to step and unstep every time out.
Ed
'76 Hobie 16
PostPosted: Tue May 24, 2011 4:28 pm
I have looked at it a few times. Only one thing I would have done different and it's to put 2 eyes instead of a rod to secure the ratchet strap. Too paranoid that the rod will bend and that hooks will slip off, but I also have a tendancy to overtighten stuff. I bought 1200lbs rated ratchet straps at costo and just can't wait to use them.
As far as the boat on the beach, I happen to have a seasonal campsite with a waterfront lot.
Here's a few pics, first few are mine, the others are of my friend's on their Getaways. Hobie album
BTW we all get to stay mast up all summer.
Marc...
PostPosted: Wed May 25, 2011 6:24 am
Nice pictures. Thanks for posting them.
I thought about using eyes to hold the strap ends but already had the rod in the shop. I am careful to put the strap hooks as close as possible to the pole so the rod can't flex much. So far so good.
Ed
'76 Hobie 16
PostPosted: Thu May 26, 2011 8:04 am
My apologies but I don't understand all the hard work and issues everyone has with single handed mast stepping. I run a rope from my cleated Jib Halyard through a pulley on the mast storage pole on the trailer and run it back through one of the swivel cleats on the forward crossbar. I stand on the tramp and lift the mast just like I would as if I had someone helping me, grab the rope, pull it tight then cleat it, jump down and hook the forestay. I lower the jib Halyard and untie the rope. As long as I haven't caught a shroud or tramp line on a rudder or rear corner casting it takes about 2 minutes or less.
I keep reading about the effort that goes into stepping the mast and wonder if I'm extremely lucky or missing something.
Ignorance is bliss????
1999 Hobie 20, Sail #1005
2001 Hobie 16, "Spirit of 76 sails" #18515. Sold
1981 Hobie 18, Dead!
PostPosted: Fri May 27, 2011 8:40 am
If you can do it, great, I think for me being 51 now, any mechanical device removing my back/shoulder from the equation is a plus. There is a bit of a safety factor too, I was lifting my 18 mast once and tripped on something on the tramp and ALMOST had a big disaster on my hands. A strong (but then pulled) muscle saved the day. McGyver it if you can, I say!
PostPosted: Fri May 27, 2011 1:25 pm
Yeah. I remember when I was in shape to lift the mast single handedly but that was before I had quadruple bypasses and turned 67!
This is why this somebody needs help getting the mast up. :D
Ed
'76 Hobie 16
