It is currently Sun Jun 21, 2026 8:26 am
PostPosted: Thu Jun 02, 2011 2:30 pm
What do you use to clean and treat your pontoons? Is there a good cleaner for removing dark smudges (from rubbing against something)? Also, do you apply a UV protectant on the pontoons?
Also, I noticed that some of the silicone(?) caulk around the pontoons is missing. Can you recommend a brand of caulk I should use to reseal the pontoon posts.
Thanks!
Bloome
PostPosted: Thu Jun 02, 2011 5:11 pm
Not sure what you'd use on a pontoon boat. I would just use regular soap and water on the hulls of my boat though. Might use Spray-9 or Fantastic on stubborn stains.
Marc...
PostPosted: Tue Jun 07, 2011 11:44 am
We just went though this with our locale group. To really get a good cleaning of your hulls, using "Slimy Grimy" boat cleaner and then coat with "Collinite" boat wax.
Both products can be searched for on the net. What our problem at Lake Arthur is you could put you boat in all clean and by the end of the day it looked coffee stained and could not just be washed off. Dave Adams was our test boat and it's working out very well so far.
Buxton
11' H16 White Lightning
79' H16 Green Lightning
PostPosted: Tue Jun 07, 2011 11:56 am
Buxton... are the stains iron related? Maybe CLR would remove the stains.
'73 hobie 16 restored 2011
'00 Seaswirl fishin boat
PostPosted: Tue Jun 07, 2011 12:13 pm
Forum search for "oxalic acid" is what you want:
http://www.hobiecat.com/forums/search.php?keywords=oxalic&terms=all&author=&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
PostPosted: Tue Jun 07, 2011 12:14 pm
Not sure if it's all iron but CLR was one of our first tries and it hardly touched the stains so we had to go with something stronger. White hulls are of course the worst. Painted hulls have no problem and the stains will get darker on your way home is you don't rinse the boat off before leaving the lake. I've started to take a gal of water with me for rinsing.
Buxton
PostPosted: Sat Jun 11, 2011 6:15 am
http://www.defender.com/product.jsp?pat ... 4&id=14027
Marykate ,,this stuff is the bomb. Fiberglass boats only, Fiberglass boats only. West marine sells it too, check out the reviews on the link below. It is a good product.
http://www.westmarine.com/webapp/wcs/st ... sNum=10381
