It is currently Sun Jun 21, 2026 1:03 pm
 Post subject: Rivets
PostPosted: Sat Jun 25, 2011 1:45 pm
I'm installing a new mast tang on my H16. I removed the old rivets and casings and the damaged tang. Anyone know if the 3/16' rivets and casings can be replaced with 1/4" rivets sans casings? Of course, the holes would have to be enlarged on both the mast and the new tang but I would think that the overall strength and reliability would be better. (?) Anyone know exactly what those casings add to the attachment?
 Post subject: Re: Rivets
PostPosted: Wed Jun 29, 2011 10:19 am
http://www.saltydogmarine.com/product_i ... 9c2a6ec822
This sums it up nicely..
PostPosted: Wed Jun 29, 2011 11:55 am
I would think one might get the same watertightness with a good shot of marine silicone or urethane sealant - first coating the rivet and then injected through the hole...
I still like the larger 1/4" rivets with the holes drilled out - since the mast holes are somewhat corroded anyway.
PostPosted: Wed Jun 29, 2011 12:01 pm
Since the tang is some 20 feet up... the holes through rivets have a lot of pressure on them when inverted under water. That and the fact that silicone fails after a few years. Caps are best. Maybe epoxy would work though.
PostPosted: Sun Jul 03, 2011 7:51 pm
Get yourself a HEAVY DUTY rivet gun. I ruined a decent one trying to set SS rivets when I replaced my main halyard cleat.
I have a yellow and white Stanley rivet setter..I think it was noted as a marine grade one or something like that. Cost about 40 bucks.
'77- H16(30804)
PostPosted: Mon Jul 04, 2011 8:24 am
Here's the one you want:
http://www.harborfreight.com/heavy-duty ... 66422.html
Changed riveting for me for good and at $20 you can't complain.
'81 H16
