It is currently Sun Jun 21, 2026 1:05 pm
 Post subject: Hull camber for hobie16
PostPosted: Wed Jun 29, 2011 2:13 pm
Looking for the proper degree of camber for a hobie 16 and where to measure it at?
PostPosted: Wed Jun 29, 2011 4:18 pm
q'est-ce que c'est camber? You mean in the battens?
PostPosted: Wed Jun 29, 2011 4:31 pm
I imagine he's referring to the camber angle of the hulls from vertical. I don't imagine it would be adjustable but if your corner mouldings are worn and sloppy at the pylon, then it could change a little, I guess.
Measuring it would be a fun exercise... :lol:
'97 Hobie 16.
Skype: rob_arnolda
PostPosted: Thu Jun 30, 2011 10:22 am
What, nobody knows the answer to this? The hulls appear to have a negative camber, to what degree?
PostPosted: Thu Jun 30, 2011 10:50 am
There is no measurement of this - mainly because up to a point, it doesn't matter.
You put the boat together and the castings/trampoline holds the boat more-or-less in the same geometry (your mileage may vary depending on how old / loose your casting/pylons are).
PostPosted: Fri Jul 01, 2011 11:14 pm
Ok, for what it’s worth, I was asking because I was gluing up a rather sloppy 84. Measuring from the outside corner of the rear of each hull (as set in a jig) I could get about 4 degrees of negative camber on the port hull and almost a neutral camber on the starboard hull. When considering the effective heeling moment I was just hoping to dial the boat in. So I glued it equally at 4 degrees. Does it really matter, probably not, but I had one chance to get it right as designed.
