It is currently Sun Aug 02, 2026 9:54 pm
PostPosted: Wed May 24, 2006 6:08 pm
I guess I should up grade my mailsheet and blocks. Sounds like 40mm or 57mm Harken's for most people. What diameter main sheet and what length? 8) Should mention that this is a 1981 boat and I probably won't race it.
Christianity, if false, is of no importance, and if true, of infinite importance. The only thing it cannot be is moderately important.
C. S. Lewis (former atheist)
PostPosted: Wed May 24, 2006 10:17 pm
Running 6:1 on 40mm or 57mm blocks, you run 3/8 sheet at 46" if you're going to trapeze. Check page 20 in the Murry's catalogue.
I just upgraded mine but I spliced the sheet. 20' of 3/8 and the rest 1/2." Makes it a lot easier to hold.
Happy Sailing,
David
PostPosted: Thu May 25, 2006 10:01 am
Happy Sailing,
David
Sorry........ Murry's catalogue? Ah, got it. Thanks!
PostPosted: Thu May 25, 2006 10:15 am
I am currently running the main sheet back through the traveler in one continueous line. Is that a good way to go or should there be 2 separate lines.
PostPosted: Thu May 25, 2006 10:21 am
Happy Sailing,
David
SOOOO....... are you saying 46" of 3/8" spliced into 20' of 1/2"?
PostPosted: Thu May 25, 2006 12:01 pm
Sorry Pilot,
I meant 46' instead of 46". I can't see in the dark. :lol: A lot of sailors run 3/8 straight through but I have large hands and holding 3/8" sometimes feels like kite string. I don't know if there should be two separete lines (because I run the other end through the traveler like you) but I use two. I tie the main sheet (spliced 3/8" to 1/2") to the travler sheet (3/8") at rigging time. I have different lengths (also different color) of traveler sheet, depending on whether I anticipate on trapezing or not. It makes everything real simple at rigging time. Are you confused now ? ? ? Well, I'm confused just explaining that. :?
Happy Sailing,
David
PostPosted: Thu May 25, 2006 12:40 pm
DavidBell47 wrote:
Sorry Pilot,
Happy Sailing,
David
I THINK I got it. Thanks muchly. :D So what kind (brand) of line did you use? And what kind of splice?
PostPosted: Thu May 25, 2006 1:02 pm
Pilot,
A good source of line info
http://www.hcana.hobieclass.com/?Page=2169
Fleet 297
PostPosted: Thu May 25, 2006 2:16 pm
John,
Thanks, nice link!
