It is currently Sun Jun 21, 2026 3:54 am
PostPosted: Mon Jul 25, 2011 12:13 pm
On youtube Annie teaches a lady to sail a H-16 for the first time, and she has some sort of white plastic material below her side rails under her trampoline that probably allows the trapeze bungees to move around without any friction or snagging the side rail material. Any idea what it is, where to get it and how much ? Looks like a clever idea to me ! Thanks!!!
PostPosted: Tue Jul 26, 2011 10:01 am
Got a link?
PostPosted: Tue Jul 26, 2011 10:40 am
Location: Latrobe, PA, USA *** Show YOUR Location - Edit Profile ! ***
I found it pretty easily- though a link would be helpful...
http://www.youtube.com/watch?v=PFliNR3wW_w
Looks like some sort of plastic covering over the sidebar aluminum.
I have closed-cell foam over mine for padding (matches boat color). Many use neoprene...
I think the usual way to apply (foam) is to use contact cement, which I tried to apply very carefully- and still ended up slopping all over the hull surface. Should use some sort of masking when working with glue on an intact boat...
Anyone know how to remove setup contact cement from gelcoat surfaces?
Based on limited success in gluing foam/neoprene to the rails I have doubts about trying to glue plastic...
But there are discussions of various ways to lead the (elastic) trap lines around the sidebar without damaging the foam. I recently re-grometted my tramp and so put a grommeted hole for accessing the tramp line. It would still be nice to have a turning block underneath but I haven't gotten to that so far...
Raise your sail one foot, and you get ten feet of wind.
起你的一只帆,和你10英尺的。 -- Chinese Proverb
William D. Latinette @ Latrobe, PA, USA w. H14 Turbo X 2... [email protected]
PostPosted: Tue Jul 26, 2011 11:27 am
From what I can see... this boat has white non-skid tape on the sidebars. That is very basic. Hard and rough on the butt! I'd use the neoprene kit. I'd bet she had to add the tape to that boat for the video shoot... what was available at the time.
Users browsing this forum: Google [Bot], jclarkdawe and 2 guests
