It is currently Sun Jun 21, 2026 1:03 pm
PostPosted: Thu Aug 04, 2011 2:37 am
I am in Australia and would appreciate advice on the best glue to use on the H16 hulls. A brand name that's available in Australia. Thanks
PostPosted: Thu Aug 04, 2011 2:45 am
Potentially silly question, but what part of the hulls are you gluing?
Has your deck separated?
Just trying to get a handle on what you're trying to achieve, here...
'97 Hobie 16.
Skype: rob_arnolda
PostPosted: Thu Aug 04, 2011 4:12 am
Sorry - I'm a dope - the question referred to glueing the hulls to the staunchions that support the tramp.
The cat is about 10 years old and there's too much movement between the hulls and the tramp.
I've searched the forum in the past - 'Glueing the Hulls' - and the resins mentioned are USA available.
PostPosted: Fri Aug 05, 2011 7:37 am
Ahhhh.... Got ya!
Uhmm, thankfully, mine was already resined when I bought it so I have yet to need to do that.
I know the Hobie dealer up here in Brisbane used to assemble his with resin (I have one which he used to own). You could contact him and ask.
http://www.sunstatehobie.com.au/
Otherwise, anyone involved in your nearest club/regatta should be able to point you in the right direction.
Sorry I cant be of more help!
Rob.
'97 Hobie 16.
Skype: rob_arnolda
PostPosted: Fri Aug 05, 2011 8:25 am
Any decent brand of medium viscosity epoxy resin will work.
In the US, we use Gougeon Brothers WEST System, which when thickened with collodial silica (CabOSil or WEST 406) to a thick paste, works well.
PostPosted: Sat Aug 06, 2011 5:23 pm
Did you try an internet search? From New Jersey (epoxy resin austrailia)I found several brands, among them System 3 and West System
http://www.westsystem.com.au/west_system/about_us
www.boatcraft.com.au
Either one of these will do the job..
PostPosted: Sun Aug 07, 2011 10:39 pm
Thanks for the advice everyone! J
PostPosted: Fri Sep 02, 2011 9:30 pm
We used West Marine 2 pack Epoxy and filler - worked really well but then found the pylons had already been glued so we concentrated on the front and rear crossbars and unable to remove the sidebars.
Had to redrill all of the 24 rivet holes due to the wear and tear on the originals and also found another set of holes in each corner - looked like the originals as they'd never been used so the boat had been well fiddled with before!
Now the hulls and frame are nice and stiff but now there's another problem (separate post) - a crack under the front crossbar. Hope to have a plate welded next week.
Thanks to all for the advice. J
