It is currently Thu Apr 23, 2026 2:18 am
 Post subject: Shroud Adjustment
PostPosted: Thu Aug 18, 2011 11:21 am
So, maybe when I rise my mast up I place the shroud pin in hole #1 from down to up cos' I've heard or read that te shroud position is determinated(?) by the skipper + crew weight and we don't weight much. Less than a 130 kilos.
But if i wanted a little more power would it be ok to place a little higher to get more rake?? Is this even the way to get more rake?? Does it even matter where you place the pin??
Thanks, I'm sorry if I sound like a newbie. I am a newbie.
 Post subject: Re: Shroud Adjustment
PostPosted: Thu Aug 18, 2011 12:52 pm
Placing the shroud in higher holes in the chainplates will lessen mast rake.
If you are new to sailing the Hobie 16, I would not be very concerned with mast rake the first season. Just leave it somewhere in the middle.
Just sail and enjoy the boat - get used to it's feel.
1977 Super Sunfish (sold)
1979 Hobie (sold)
2008 Hobie 16 (sold)
2023 Hobie 16
John
PostPosted: Fri Aug 19, 2011 7:38 pm
Here's a go-by that I pulled off a tuning guide:
<275lbs - Bottom hole of stay adjuster
275 - 294lbs - 2nd Bottom hole of stay adjuster
294 - 316lbs - 3rd Bottom hole of stay adjuster
>319lbs - 4th Bottom hole of stay adjuster
Of course it's just a go-to, you'll have to adjust to your skill, conditions and preferences, and the rest of your boat tuning (rudder rake mainly).
'81 H16
