It is currently Sun Jun 21, 2026 1:05 pm
PostPosted: Wed Aug 31, 2011 7:12 pm
I have drilled out a broken tiller end cap (10400010) and have the replacement part. There are no holes in the replacement to rivet. Do I just drill the holes and rivet or is there another method to attach replacement end caps?
And a related question. on the other joining arm there is a screw that allows that end cap to be adjusted in and out from the tube. The screw keeps loosening up. If I don't keep an eye on it, the joint assembly will come right out. What is the best way to keep it from loosening?
PostPosted: Wed Aug 31, 2011 8:04 pm
Replace the nut with a nylon insert, self-locking nut.
PostPosted: Thu Sep 01, 2011 8:09 am
In a pinch, you could double-nut it, but a self-locking nut is best.
Marc...
PostPosted: Thu Sep 01, 2011 8:20 am
Yes. Line it up properly and drill it out with a 3/16" bit. Pop a new rivet and go!
Sail Revolution
Join us on our new FB Page!
