It is currently Sat Jun 20, 2026 11:58 pm
 Post subject: first trip
PostPosted: Mon Sep 12, 2011 3:22 pm
I finally got to take my 1983 16 for a spin yesterday. The wind was minimal but we got an occasional gust of 10 mph at most. We managed to sail down the Caloosahatchee and back up again from Franklin Locks. At one point we docked at a marina. I let the sails all the way out but shortly after jumping on shore, a gust of wind made the boat try to take off. I had it tied down but when we jumped back on, no matter what I did I could not get the boat to sit still, so I untied my docking lines and we just kept going. Is there anyway to cage the beast without lowering the sails, or relying on docking lines to hold it? Also, even though we managed to sail down the river and back up again, I honestly could not determine the wind direction the entire time. I could see flags but it only added to the confusion because they appeared to be blowing opposite the direction that my boom was being blown. The flags were pretty high up so maybe there was a wind shear. What do you guys use on board to determine wind direction? I just pointed my boat as close to the desired course that it would move and played with the sails to achieve the best speed. Keep in my that my friend and I are completely self taught and this is my second time ever sailing and my first time on this boat.
Straighten me out! Thanks.
'73 Hobie 16
1970's styrofoam snark
 Post subject: Re: first trip
PostPosted: Mon Sep 12, 2011 4:07 pm
Do you have any telltales on your shrouds or bridles?? Without them, you're guessing! If you can get your hands on some old cassette tape or even a purpose built item, it will make life a lot easier for you.
Have a look around or do a bit of a search on "apparent wind". Tis will teach you about wind direction in relation to the movement of the boat. It's pretty straight forward once you have it explained to you.
I'd doubt there would be a windshear at ground level or thereabouts, so you may have just gotten a little confused - it can be easy to do in the early days.
Theres a guy on YouTube who goes by the handle of "ppconsultant" and he has some absolutely fantastic videos that he's made. Check them out and soak up what he says.
Glad to hear you finally got out there!
'97 Hobie 16.
Skype: rob_arnolda
PostPosted: Mon Sep 12, 2011 4:19 pm
Tie a strip of video tape a few inches long to the bridle wire on each side. If you have a hard time finding an old tape to steal a couple strips from any strip of ultra thin plastic ribbon would probably work. If you sail with other people somebody might already have a video tape just for that purpose. The other option is to go to your local sail shop and get a wind indicator that attaches where the bridles and forestay connect. Can't remember the brand names off the top of my head but there are 2 that I am aware of.
Big Dan
1982 H16
Hot Flash #68984
PostPosted: Tue Sep 13, 2011 7:16 am
Instead of cassette tape, I use pieces of wool yarn. Cassette tape will tear off when trailering the boat at highway speed but the yarn won't. When sailing, always look at the windward tell tale. The downwind side is affected by air coming off the jib and isn't indicating wind direction.
Howard
PostPosted: Tue Sep 13, 2011 7:24 am
First of all, welcome to the world of sailing and Hobie Cats!
Docking: if you want to pull up to a dock, there's not much you can do to stay still for sure short of dropping the sails. The next best alternative if you're only going to be there for a minute is to dock with the bow facing into the wind, but if the wind shifts then the boat may try to sail away. The best way is to pick up a mooring instead of going into a dock, as the boat is then free to rotate 360° and always face into the wind. Obviously this makes it harder to get ashore, and I wouldn't leave the boat unattended with the sails up regardless.
Wind direction: determining the wind direction can be tricky when you're starting out, particularly on a river or something like a Hobie. as HiFiRobbie mentioned, look up "apparent wind" (will make the wind seem like its coming more in front of you than the flags indicate). I'm not familiar with the river you were on, but you may have also been seeing some local wind swirl due to the surrounding topography- generally the wind in a narrow river will be funneled to slightly more of a upstream/downstream direction than the prevailing wind above the river banks (what the flags see).
Definitely find a cassette tape to use as telltales for the shrouds- if you don't have any tapes, eBay, Salvation Army, and older friends/relatives are all great resources to find them. Having the telltales on the shrouds/bridles help a lot in determining the wind direction. I wouldn't pay for one of the wind arrows ("windex") that goes on the bridle yet; personally I think that they're more trouble than they're worth until you're at a higher level.
I personally prefer the tape over yarn, as I feel that it does a better job of picking up the slight changes/puffs on very light air days, but hrtsailor is right, it will tear off at highway speeds (or even really big gusts- I keep a spare cassette in my sailing box). However, its all a matter of personal preference, both tape and yarn work, as will ribbon.
1990 Hobie 18SX #2077
PostPosted: Tue Sep 13, 2011 7:37 am
You must have launched in East Fort Myers. A river is one of the hardest places to sail. Between the wind bending at every tree and the current moving you have to be on your toes to keep the boat moving.
Take your eyes out of the boat. Look at the water for ripples and their movement. Be prepared for openings on the river bank for the wind to blow through differently.
Tike Pete launches out at the Sanibel Causeway. The Gulf and Pine Island sound are great places to sail.
Can you launch at the sailing center at the north end of the 41 bridge?
PostPosted: Tue Sep 13, 2011 2:58 pm
I think I have some tapes I can take apart. As for location, I doubt I will launch at the locks again. I will try to launch at the sailing center that jkkartz suggested.
Thanks for the help.
'73 Hobie 16
