It is currently Sun Jun 21, 2026 1:20 pm
PostPosted: Tue Jan 31, 2012 4:39 pm
I just got a set of EPO2's for my boat and I want make sure thy they are drilled corectly and there is a spec for adjustable and non adjustable. Thanks
PostPosted: Tue Jan 31, 2012 5:11 pm
Adjustable castings have a bolt visible on the top of the upper casting. That moves a plate fore and aft on the inside of the casting. The plate trips the cam. Older ones have a pin (that trips the cam) pressed into the casting visible from either side.
PostPosted: Wed Feb 01, 2012 7:33 am
You wouldn't think the small offset would make a big difference but it really does. I picked up a 14 Turbo with adjustable rudder arms. One of the rudders was drilled to the non-adj spec. When the rudders were locked down the non-adj rudder was nowhere near vertical and not anywhere close to being aligned with the other. If you have the older rudder arms you might want to try to find a set of newer adjustable's before drilling your expensive EPOs.
PostPosted: Wed Feb 01, 2012 9:58 am
Does any one have a pic of what they look like or a vender that would sell them
PostPosted: Wed Feb 01, 2012 2:57 pm
Superficially, they look identical.
Look closely, though.
Non-rake adjustable will have a hole on each side where the locking pin is:
Rake adjustable has a bolt on the top and no hole on the side:
Vendor? How about a Hobie dealer?
