It is currently Sun Jun 21, 2026 1:19 pm
 Post subject: Rudder question
PostPosted: Mon Feb 06, 2012 2:35 pm
I have looked around and not really found an answer. I was wondering if the 17,18 or wave rudder castings would fit on a 16?
 Post subject: Re: Rudder question
PostPosted: Mon Feb 06, 2012 3:34 pm
No.
Gudgeon spacing is different and the rudder pin passes through the deck lip on the 16 but not on the others.
Edit: I was looking for this post, but apparently it was deleted . . .
Here's a diagram I did for a guy looking to use 16 castings on an 18. You can see how much different they are.
PostPosted: Mon Feb 06, 2012 4:16 pm
Cool thanks that's what I needed to know
PostPosted: Tue Feb 07, 2012 2:08 pm
Now with that out of the way should I buy a set of adjustable rudder castings or should I just get mine redone?
PostPosted: Tue Feb 07, 2012 3:15 pm
Adjustable castings can make setting up the rake easier and easier to maintain a tight fit to the cam which holds the rudder all the way down... but, you can achieve correct rake without them. I'd say, save the money for a new jib.
