It is currently Sun Jun 21, 2026 1:16 pm
 Post subject: Git rot?
PostPosted: Mon Feb 27, 2012 1:23 pm
The top of one hull and several spoots on the sides of the hulls are delaminates. How much Git Rot do I need. Epoxy always seems to go further than you expect, but I've never done anything like this.
 Post subject: Re: Git rot?
PostPosted: Mon Feb 27, 2012 6:19 pm
It depends on how large your spots are. It should not take a lot of git-rot to do it. Unless the delam is really bad, there's not usually all that much space to fill. The trick is to make sure you get into all the gaps and don't let it leak out. Start at the bottom and use masking tape to cover the holes as you go up. Be very careful not to drill through to the inside of the hull.
I did a spot about 10" x 10" on the top of my hull (where the trailer strap crosses) and used less than 1/3rd of a small bottle.
oh yea, don't use straps across the tops of your hulls. :)
