It is currently Sun Aug 02, 2026 11:34 am
 Post subject: Problem with the main
PostPosted: Wed Jul 19, 2006 4:25 pm
This is my first year sailing and both times I have taken it out, I can't get the main to go up all the way. It looks like it is all the way up when looking up and when I let go of the halyard nothing moves. This would make me think the halyard was locked in. However, there is probably 3-4 inches more that it looks like I can raise the sail. The gooseneck is resing on the downhaul cleat and this gives me no room to adjust the downhaul. Is there something that it could be getting caught on that I don't know about? Any help is appriciated as I just can't figure this out.
PostPosted: Wed Jul 19, 2006 4:33 pm
See the recent post titled Rigging ?s for answers
PostPosted: Wed Jul 19, 2006 4:41 pm
Have you tried attaching the sail with the mast down?
PostPosted: Wed Jul 19, 2006 6:00 pm
Is there any chance that the mast has been dropped and maybe a ding put in the slot for the sail? Or maybe the crimped on slug on the halyard is getting stuck in the mast head? Best bet is to drop the mast and check it out by running the sail up the mast laying in the yard. Good Luck!
 Post subject: FAQ
PostPosted: Thu Jul 20, 2006 11:20 am
http://www.hobiecat.com/community/viewtopic.php?t=371
<<Raising the mainsail of a Hobie can be more difficult than need be.
Several factors can cause the mainsail to be difficult to hoist:
Dirty luff ropes and luff tracks. These can be cleaned with soapy water and a scrub brush. If you want to use a lubricant, keep away from oils and waxes that can attract dirt. Use a dry silicone spray. Most all Hobie sails now have a Teflon threaded bolt (luff) rope to ease the hoisting effort.
Battens and sail shape. The battens stiffen the airfoil shape of your sail. Over tensioning of the battens can cause a couple of problems. Luff protector caps can be forced against the mast and cause drag when hoisting. The battens also force the sail shape into a curve. The luff curve (seen when laying the sail out on the ground, as a large arch) is typical to Hobie Cat main sails. The sails "airfoil" shape is mostly created by the miss-matched mast bend and luff curve of the sail. The luff curve is more than the likely mast bend and when the mast is straight (while hoisting) the difference is dramatic. This luff curve going up the straight mast can cause significant drag and hoisting problems when done incorrectly.
Outhaul. Be sure the outhaul is fully released before hoisting.
Hoist Technique:
Keep the batten tension to a minimum. Hoist the sail slowly, while feeding into the mast opening. When the sail gets about 3/4's of the way up, begin aggressively feeding at the bottom opening and reduce the amount of halyard effort. If the halyard is pulled tight when the sail is not being fed into and up the track, you will have problems. The sail luff will pull taunt and the curve shape will bind in the (straight) mast track. Lower the sail slightly and begin feeding again.
The best way to feed the sail is to stand in front of the mast and reach around either side to "sandwich" the sail between two hands (above the feeder opening) and push the sail up the track. Pull with the halyard, only the slack created, then feed again. If the sail binds, lower slightly and begin feeding again. This technique can be done by one person, but is certainly easier with two working together. It is VERY important that the person on the halyard only pulls the slack up the mast and does not get ahead of the feeder.
Locking the Hobie 14/16 halyard:
Once the sail is fully hoisted (be sure that the sail is fully inserted into the feeder). Pull the halyard forward of the mast by 3-4 feet. Hold the halyard on the centerline of the mast. Pull hard and hold the tension while bringing the halyard into the mast. Release the halyard tension and see that the sail remains fully hoisted. This seats a small bead, in the halyard, under a two finger prong "hook" and the top of the mast. If the sail slips down when downhaul tension is added, repeat the final hoist technique again. Be sure the bead is clear to pass the hook before pulling tension on the halyard. >>
