It is currently Sat Jun 20, 2026 10:10 am
 Post subject: hobie 14/16 trailer
PostPosted: Wed Jun 06, 2012 3:47 pm
Hi, Would a hobie 16 fit a hobie 14/prindle 16 trailer? just trying to figure out what i can get.
2008 Laser Radial/4.7 #190471
S.S.S.
S.Y.S.P
 Post subject: Re: hobie 14/16 trailer
PostPosted: Wed Jun 06, 2012 4:50 pm
On most trailers, you can adjust rollers in or out. So if the rollers are adjustable from side to side, it will fit for sure.
Marc...
PostPosted: Wed Jun 06, 2012 5:21 pm
It all depends on the size of the trailer. There are some pretty small Hobie 14 trailers out there with bar spacing that would probably not work for a 16. It's not a definite answer. You need a trailer with a MINIMUM load rating of 350 LBS. Closer to 500 LBS would be better. The trailer crossbar spacing should be the same or close to the boat's crossbar spacing, and the tongue needs to be long enough that it extends at least two or three feet past the bows.
PostPosted: Wed Jun 06, 2012 5:51 pm
so do you know the sizes? because there is a 14 for sale near me for the same price on a 16 trailer but all it is are hulls a trailer.
S.S.S.
S.Y.S.P
PostPosted: Thu Jun 07, 2012 11:31 am
Nope, measure your boat. All you really need is the distance between the front and rear crossbars and the distance from the front crossbar to the bow. The trailer crossbars should be approximately in line with the boat's crossbars. The trailer axle should be located approximately centered between the crossbars. The trailer tongue should be about two to three feet longer than the distance from the front crossbar to the bow. Also, a H16 is 6" wider than a H14, so you need to make sure the crossbars can accomodate the wider boat. It isn't rocket science- bigger is better (to a point). Too small will be the bigger problem. If you're buying a Hobie 14 trailer, there's a chance it would be too small. A Prindle 16 trailer would probably be fine. Also verify the trailer and axle load ratings.
