It is currently Sat Jun 20, 2026 8:10 am
PostPosted: Wed Jun 20, 2012 6:15 am
I am wondering if the 4 aluminum extrusions that make up the square frame the tramp attaches to are sealed. I am assuming they are not. I have some holes in my front tube (above the dolphin striker) where rivets used to hold the original jib blocks and I am wonderinging if water gets in there if it will just drain right out?? I am lake sailing.
2015 Tandem Island
Massachusetts and Squam Lake New Hampshire USA
PostPosted: Wed Jun 20, 2012 6:16 am
No they are not sealed and do not need to be.
Marc...
PostPosted: Wed Jun 20, 2012 7:04 am
2015 Tandem Island
PostPosted: Wed Jun 20, 2012 11:05 am
No they are not and the connections to the corner castings are loose enough that I would think water could get out. I wouldn't worry about it unless you hear a ton of water sloshing around inside.
Zach
