It is currently Sat Jun 20, 2026 9:34 am
PostPosted: Thu Jun 21, 2012 4:37 pm
Hey all my main traveler cam cleat has broken off the cross bar. It appears that it had one rivet and two screws holding it on. Do you think it would weaken the cross bar if I just drilled the three holes all the way through and put lock nuts on the underside to hold it in place. This is a 1981 model and has been modified so I'm not sure if this was the original setup. The two holes already drilled appear to be aftermarket mods.
Thanks in advance
Will
PostPosted: Mon Jun 25, 2012 4:28 am
This happened to me just this Saturday. Im curious to see what kind of suggestions come up.
PostPosted: Mon Jun 25, 2012 4:46 am
Will, I did see this response in another post.
No - larger screws will interfere with the rotation of the traveller cleat.
You can offset the base slightly - about 1/2" and drill new holes for the rivet / screws. Be careful not to drill the screw holes too large. When you screw them in, turn them like a tap - 1/2 turn forward, 1/4 turn back, repeat. That'll help "cut" the threads into the aluminum extrusion.
This could provide an easy solution. Whatever is done I recommend applying a little Lanocote where the stainless steel screws and rivet contact the aluminum crossbar. Lanacote is an excellent product used to reduce galvanic corrosion between the dissimilar metals. Do not use an aluminum rivet when reattaching the base plate. Aluminum will rip right off. Monel is preffered but West Marine sells stainless rivets that work great.
Martin
PostPosted: Tue Jun 26, 2012 11:51 am
Do either of you live in So Cal?
I have a 1981 H16 tramp frame I am willing to give away if someone wants it. It is in great shape.
You just have to come get it.
1977 Super Sunfish (sold)
1979 Hobie (sold)
2008 Hobie 16 (sold)
2023 Hobie 16
John
PostPosted: Tue Jun 26, 2012 5:09 pm
Thanks for the gracious offer but I'm Florida. Used to live in San Diego and miss it every day.
