It is currently Sat Jun 20, 2026 7:39 am
 Post subject: Jib tension question
PostPosted: Sun Oct 07, 2012 2:34 pm
Hey all!
I searched but couldn't quite find an answer.
I was sailing on Friday and when winds hit my jib it starts roaring. In between the battens flutters. I'm wondering if I need to tighten my jib. Is the forestry line supposed to be tight or somewhat loose? Does the jib "replace" the forestry line.
Thanks for the input,
-Matthew
 Post subject: Re: Jib tension question
PostPosted: Sun Oct 07, 2012 5:44 pm
Yes, the Jib halyard should be tight and the forestay should be loose. The wire in the Jib is actually what holds the mast forward once it's fully rigged.
cron
