It is currently Sun Aug 02, 2026 1:50 pm
 Post subject: Attaching the trap wires
PostPosted: Sat Aug 12, 2006 7:46 am
I just finished repairing a h-16, 70's model. The mast tang has only one hole in it. Would it be safe to attach the shrouds, forestay, and the trap wires to this one shackle? Should I replace the tang with a 3 hole style?
Thanks,
hopsing
PostPosted: Sat Aug 12, 2006 10:43 am
well i know it would be safer to have the 3 hole style tang, but the 14s i know were originally rigged with all 5 wires on one shackle, and althought the 16 rig is more powerful, i think for recreational sailing it shouldnt be much of a problem. still, i would feel safer with the other tang
Peter Scranton
'14 Tandem Island "Awesome"
'03 Windrider Rave "Menage a Trois"
PostPosted: Tue Aug 15, 2006 8:40 pm
Whichever way you go make sure and safety wire everything. It's a big surprise when a shackle comes undone and you either end up in the drink or your mast falls down.
PostPosted: Wed Aug 16, 2006 7:03 am
The original 16 has all five wires on the bow of the shackle.
If you have a second trapeze, the wires for that go on the pin of the shackle on either side of the mast tang.
 Post subject: mast tang
PostPosted: Fri Aug 18, 2006 1:22 am
Also, check for cracking on the tang. Quite a few older 16's I see have small cracks. If so, change it to the 3hole.
Sail Revolution
Join us on our new FB Page!
PostPosted: Wed Aug 23, 2006 12:20 pm
I don't quite understand that. Could you provide a pic? I bought a set of trapeze wires to replace one that had frayed, when I went to replace it, it turns out someone had added a loop to the frayed wire and extending a second loop to hang the second traps from. Of course it was the modified wire that was deteriorated so now I don't know how to hang two good sets. Thanks.
