It is currently Sat Jun 20, 2026 8:09 am
PostPosted: Fri Dec 28, 2012 11:33 pm
Greetings.
I have some corrosion in one pylon of my beloved hobie. Its a late 80's /early 90's model. My local dealer was wary of any form of any sort of welding repair to the pylon as he stated the heat generated would :
1.degrade the glue joint holding the pylon in place within the hull;
and
2.possibly damage the fibreglass
So I have glued 2mm(1/8") curved alum plate inside the pylon (on both sides) with West epoxy. I then glassed over the alum with thoroughly wetted out chopped strand mat. Over this I applied a coat of epoxy/fill mixture to ensure it is all waterproof. Prior to any glueing I degreased the pylon and alum patch, gave them an acid wash and then hit them with a wire brush.
I am happy with the result but I have been searching the web for advice on bonding alum to alum and it appears that quite a few seem to think it is not a permanent solution. The only way of bonding is to weld apparently.
What I can't figure out is why it appears to be satisfactory to glue the alum pylons to the boat with polyester resin when it is constructed - yet an epoxy glue will not hold.
In short - will my repair job work? ( I can attach photos once I figure out how to do so)
PostPosted: Sat Dec 29, 2012 11:41 am
You might want to check out this previous topic:
Hobie 16 pylon replacement
http://www.hobiecat.com/forums/viewtopic.php?f=14&t=40821
Tim
84 H16
82 H16
87 H14T
Tortola Sails: 115222
Blue Prism Sails: 88863
Clearwater, FL
