It is currently Sun Jun 21, 2026 8:33 am
PostPosted: Thu Dec 27, 2012 8:10 am
can I use a hobie 14 mast in a hobie 16. ?? :?:
PostPosted: Thu Dec 27, 2012 3:09 pm
Location: Latrobe, PA, USA *** Show YOUR Location - Edit Profile ! ***
Yeah, why not, it's a "free country" !
Realize that your H16 sails, standing rigging, etc. will not work.
Also, you will probably be banned from any 'real' racing events.
But if you work out all the stuff you could sail the boat- which is probably most important.
(Realistically, if you have an H16 you should probably just find an H16 mast in good shape... unless you have H14 sail, etc. and are ready to spend the time.)
Raise your sail one foot, and you get ten feet of wind.
起你的一只帆,和你10英尺的。 -- Chinese Proverb
William D. Latinette @ Latrobe, PA, USA w. H14 Turbo X 2... [email protected]
PostPosted: Thu Dec 27, 2012 3:19 pm
regarding the hobie 14 mast and sails in a hobie 16 is that I have a good 16 hulls, and a good hobie 14 mast and sails. Im no interested in racing only have fun without spending lot of $$ in a new hobie 16 rigging. :mrgreen:
PostPosted: Thu Dec 27, 2012 3:51 pm
With what you have, why not try?
You'll lose about 4 feet of mast, and a bit of boom and sail area. H-16 really needs a jib to tack, so hopefully you have a jib. Stays will probably have to be replaced, as the length isn't going to match. I doubt you'll find the right size stays off the shelf. The helm on your boat is going to change (probably more lee helm) as the center of the sail moves forward with the smaller sails. If you add trapeze wires, the pull on the mast will be a bit lower then normal on an H-16, and you'll probably have more leverage.
You'll under-perform in light and moderate winds, but will be able to handle heavier winds a bit easier (less sail area). It would be a nice cruiser, but you wouldn't be the fastest boat in town.
It's probably going to take a bit of experimenting on the setup. Mast rake will produce some interesting affects. And the foot or so less in the bow will change the jib angle a bit. It will be interesting to hear exactly how this works out.
Or you could try trading the H-14 for H-16 stuff.
Best of luck,
Jim Clark-Dawe
PostPosted: Sat Dec 29, 2012 6:29 am
Thanks,, I was thinking a hobie that can handle high winds(usually in my area)with spare parts that I have (half h14,half h16) at home without spending some $$ and have fun in a cruise mode. any other help will be appreciated.
thanks and happy new year !!!!!! :D :D :D :D
PostPosted: Sat Dec 29, 2012 6:42 am
Keep in mind that the H14 mast cross-section is a lot smaller than the H16. If you overload it by putting it on the larger H16 and sailing in high wind (with crew??) there is potential to snap the mast.
I think you're better off using the proper H16 mast/rig that was designed for the boat. The boat will sail better and and be more enjoyable and will probably end up costing you less in the long run.
PostPosted: Sat Dec 29, 2012 8:32 am
Sometimes a idea is not a good idea
This is one of them
Get some parts and get your 16 up and running
Used parts are cheap and sometimes free
Remember this is the Great Hobie 16 and it should be treated as such
Former Hobie Admiral Gary
