It is currently Sat Jun 20, 2026 3:03 am
 Post subject: Trapeze any hobie 16?
PostPosted: Fri Jan 11, 2013 9:35 am
I'm picking up a 16 this weekend for $900, I know it does not have trapeze wires or harnesses. Is it safe to assume I can pick up trapeze wire kits for it so we can double trap? I'm assuming every hobie 16 has the tang where one can hook in trap wires etc...?
#firsthobie
PostPosted: Fri Jan 11, 2013 9:40 am
I'm fairly certain they all have the tang. Where are you located?
Zach
PostPosted: Fri Jan 11, 2013 10:08 am
Yes, there are separate holes on the mast tang specifically for connecting the trap wires. All H16s can be rigged with trap wires.
I recommend you download a copy of the Hobie 16 assembly manual from this site. It should answer many questions you may have.
PostPosted: Fri Jan 11, 2013 12:55 pm
I bet when you pick up the boat you will find the trap wires balled up under a life jacket or something.
Otherwise yes, all hobie 16 are set up for trap wires.
Sail # 10505 or 277
Image Image
PostPosted: Fri Jan 11, 2013 3:41 pm
Older boats had a single hole in the tang... still OK to set up as double trap. The new tang makes it easier (3 holes).
PostPosted: Sun Jan 13, 2013 1:15 pm
Located on Lake Crescent in NORTHWEST Washington. Hoping to meet with the hobie crew in Seattle once it warms up a bit.
I already got that manual! U betcha! ...that's how I knew tang wasn't referring to a citrus drink :)
PostPosted: Fri Jan 18, 2013 12:57 pm
Now THAT's funny!
Steve
