It is currently Thu Jun 18, 2026 12:52 am
PostPosted: Thu Jul 04, 2013 12:05 am
After 25+ years I once again own a H16 :-) This claimed 84 model needs a bottom job... so bought all the epoxy, glass, etc. Have one 4" crack in the bottom of the hull two feet behind the front post. Upon drilling a couple holes to open it a bit, I was happy to find the foam sandwich does not go to the bottom of the hull. When the crack is probed, however, by pushing a small 3" screw driver blade up into the hull I am finding something loose inside about two inches above and along the length of the crack. I cannot see through the crack into the hull but it feels fairly big. Any clue what this may be? I hope to repair the crack from the bottom but this loose item makes think top level access may be required. Thanks.
PostPosted: Mon Jul 08, 2013 4:43 pm
Sand bag placed in there by an angry employee on a late Friday afternoon.
No, actually it is probably the floatation block of foam.
PostPosted: Tue Jul 09, 2013 6:01 am
Sounds to me like a loose shoe....
The post goes down inside the hull, and 'sits' inside a 'shoe' which is glassed to the bottom of the hull. In other words, the shoe is the bottom support of the post.
With age...sometimes that shoe will work it's way loose. Search the Forum for repair options.... which usually involve an incision (often from the top by cutting a porthole), and re-glassing the shoe.
2015 H16, with spin,
PostPosted: Tue Jul 09, 2013 11:41 am
I agree, loose pylon shoe. The crack in the hull near the pylon is a dead giveaway. Download the Sept/Oct 2009 Hotline. It has a very good explanation of what is going on and how to repair it.
PostPosted: Tue Jul 09, 2013 4:18 pm
I put a photo of what the shoe looks like in a facebook album. If Image itself does not show up, follow link at bottom.
https://www.facebook.com/robert.buxton. ... 366&type=3
Buxton
18' T16 Silent Lightning (16' T2 Hybrid)
11' H16 White Lightning
79' H16 Green Lightning
PostPosted: Tue Jul 09, 2013 5:18 pm
Buxton, neither one works for me.
Steve
'82 Hobie 16
Sail #64567
PostPosted: Tue Jul 09, 2013 5:33 pm
I'll try again, the photo of pvc rack in the same album showed up in my other post?
https://www.facebook.com/photo.php?fbid ... =1&theater
Buxton
PostPosted: Tue Jul 09, 2013 5:49 pm
Much better !
Steve
'82 Hobie 16
Sail #64567
PostPosted: Wed Jul 10, 2013 6:53 am
could be the flotation form that has come away from the hull....
look at this 14 the 16 is similar .
viewtopic.php?f=17&t=3009
•Present boat -1998 Hobie 16 Solana Sails furling jib[/size]
PostPosted: Wed Jul 10, 2013 12:35 pm
Thanks all for the responses. Upon opening the cracked area to patch with fiber cloth and epoxy, I could see it the loose object was the flotation foam. I read somewhere that this foam is intended to be loose.
