It is currently Sun Aug 02, 2026 11:34 pm
 Post subject: Comptip glue question
PostPosted: Sun May 04, 2014 12:48 pm
I got this glue for reinstalling comptip from local sailing store. They ordered from Hobie (I think) but it came with no instructions and local store wasn't much help anyone used this before? I am not putting a new tip on just needed to seal mast better and put old tip back on.
PostPosted: Sun May 04, 2014 5:43 pm
There is a plastic divider on the package that keeps the two parts of the epoxy separated. When you're ready to use the epoxy, slide off the plastic divider and kneed the two parts of the epoxy together really well. Then cut off a corner of the epoxy package and squirt out the epoxy onto your comptip. Use a plastic spreader to coat the tip and then insert into the mast. It's a good idea to do a dry run on the fit up before you commit to using the epoxy. Sometimes the comptip needs to be sanded down a little to fit in the mast.
PostPosted: Sun May 04, 2014 8:01 pm
And you are going to want the space (5-10 thousandths) for the epoxy.
www.thehobiewayoflife.com
PostPosted: Mon May 05, 2014 4:24 am
Ok thank you. How long does it take to set up?
PostPosted: Mon May 05, 2014 1:46 pm
Could not see product # but betting you can find info on this site...
http://www.resinlab.com/adhesives/adhesives-epoxy
1980 H16
PostPosted: Mon May 05, 2014 2:09 pm
Set the mast on sawhorses or something to keep it aligned while setting up. I'd guess 45 minutes for partial cure and 24 hours before I'd move it or sail.
PostPosted: Mon May 05, 2014 5:49 pm
Thanks guys, the glue is from resinlab EP1225 black
