It is currently Mon Aug 03, 2026 12:40 am
 Post subject: Larger Trailer Tires?
PostPosted: Sun Jul 27, 2014 5:11 pm
Rookie here again. Since I always have to travel an hour to a couple hours to reach the area lakes best suited to sailing my trailer has come under my close scrutiny. The boat is a '73 and the trailer appears to be a typical Hobie Cat trailer of that vintage. As I'm cruising the highway at 55 I can almost hear the 4.80-8's whizzing along.Has anyone had experience with fitting a larger size tire and wheel combination on one of these trailers? There appears to be a good four inches of clearance between the tires and the trailer's fenders such as they are.I can't picture the leaf springs compressing much what with the light weight of the boat. Any ideas? Any resources? Thanks in advance. lots of good knowledge here.
PostPosted: Sun Jul 27, 2014 5:46 pm
Get a new set, 4.8 - 12"......or even something wider than 4.8...
Bill 404 21SE
PostPosted: Sun Jul 27, 2014 6:14 pm
Yes, going up to a 12" wheel is a common upgrade and a good idea. You will reduce wear on the tires and on the bearings and increase the load capacity of the wheels. 4.80 x 12" would be the next size up. You could also go to a 5.30 x 12" which would be a wider tire, but probably a bit overkill. Make sure you get a wheel that has the same bolt pattern as your hubs since they could either be 4 lug or 5 lug. As far as the fenders are concerned, there is probably enough clearance that you won't have to make any modifications, but even if they end up close, it should be pretty easy to relocate them. At worst, it would likely just be a matter of drilling a couple new holes or modifying the fender bracket.
If you're unsure the last time your trailer has been serviced, it would probably be a good idea to pull the hubs and inspect the condition of the bearings & grease. Also check the axle and U-bolts for cracks or excess rust. I can speak from personal experience here that trailer breakdowns are not fun. Also make sure you carry the proper size lug wrench for your trailer lugs - this may not be the same size as your car's lug wrench.
PostPosted: Mon Jul 28, 2014 6:48 am
I have always gone tall and wide on Hobie trailer tires. Long long ago I used some old Chevy Vega 13" wheels and tires on my 16. If you go tall and wide keep the best old tire and wheel as a spare.
The usual advise on the trailer upkeep is to the point. CHECK EVERY NUT AND BOLT. Keep the bearings in good shape use greaseable dust caps keep a spare bearing SET IN THE HOBIE HELL BOX.
REMEMBER THAT TRAILER TIRES USUALLY ROT LONG BEFORE THEY WEAR OUT ABOUT 10 YEARS OR SO AND THEY ARE A LITTLE DICEY
A trailer problem on the road is negative fun at best.
Former Hobie Admiral Gary
PostPosted: Mon Jul 28, 2014 3:48 pm
Like you, my vintage trailer came with 8" tires. I quickly upgraded to 4.8x12; a cheap, easy and quick solution to those old tiny ones. You can either shop online or just drop into your local WalMart - noreal difference in the tires as they are all cheap with a short lifespan. As the load is pretty light, they might last three years. I use the same tires on some pop up campers that I rent out and need to replace them annually - but they are in use pretty much all weekends from late spring to early fall, and with a load heavier than an H16. Not at all uncommon to lose tread and have a blowout.
Also, strongly recommend that you repack the hubs. Neglected that one several years ago. Killed my bearings and wound up stranded at a truck stop an hour outside of Chicago while hauling a heavy monohull.
Lastly, double check the lights. On a rig that old, things are likely to be corroded/disconnected/shorted/etc. Good luck!
PostPosted: Wed Jul 30, 2014 5:37 pm
Last Saturday I finally installed the 4.8-12 wheels that I bought a year or so ago. I had to relocate the fenders using existing holes on my Holsclaw. Of course the trailer rides a few inches higher but I will be dropping the crossbars under the main frame so I will end up lower than before.
The new wheels do not fit tightly around the hub center. Therefore the lug bolts end up locating the wheel. I also treated myself to new bearings and it was a sweet ride down to the OBX and back over the past few days. These are HD galvanized wheels from Backyard Boats.
'00 H16 #104691
Old Holsclaw trailer
My Hobie 16 pages
PostPosted: Wed Jul 30, 2014 5:43 pm
While you are working on the hubs and wheel bearings add a set of Bearing Buddy's to them. Make it easy to add grease to the wheel bearings before immersing the wheels in cold water. A lot less likely to suck in water when you do this.
