It is currently Fri Jun 19, 2026 8:29 pm
PostPosted: Wed Jul 30, 2014 1:40 pm
I´m cannot find the entry source for large amounts of water on my sartboard hull (H16, 2002).
while sailing, it takes usually less than 60 minutes to be almost full.
We´ve know very much this kind of boat and we´ve tried to locate the posible water intake sources in the logical spots but cannot find anything.
Can anyone provide a list of posible points to check. Specially the most uncommon! and also procedures for testing leaks at hulls
PostPosted: Wed Jul 30, 2014 2:39 pm
You need to do a bubble test to find the leaks. Put a hose in the drain plug hole and blow some aire pressure into the hull or hold the exhaust of a shop vac near the drain plug to put positive pressure on the hull. Then take a spray bottle filled with soapy water and spray the entire hull at all thru-hull fittings and all along the hull/deck seam. Bubbles will form where there are leaks.
Considering how badly your hull leaks, it should be very obvious where the hull is leaking.
PostPosted: Wed Jul 30, 2014 2:42 pm
Pylon shoe pop the hull?
Do the shop vac test as described above... With that big of a leak it should be easy to find.
www.thehobiewayoflife.com
PostPosted: Wed Jul 30, 2014 2:47 pm
The deck joint where the shroud anchor goes - that is a typical spot to leak.
Jacques Bernier
http://www.hobie.com/
PostPosted: Wed Jul 30, 2014 3:11 pm
My guess: Wear on the keel is likely thru the hull and hard to see when on the shore.
PostPosted: Wed Jul 30, 2014 4:43 pm
If the hull is full of water Pulling it on the trailer should find the leak. water coming in this fast should have a large hole or crack that is very easy to find. I think Hobie Matt could be close on the problem Careful putting pressure on the hulls They can cause a bunch of damage.
Have you ever replaced the drain plugs and housing and o ring and or checked the silicone sealant around the drain?
Former Hobie Admiral Gary
