It is currently Mon Aug 03, 2026 10:47 am
PostPosted: Fri Aug 01, 2014 9:09 pm
Just want to make sure I have these installed right... Can someone confirm the travel release pin goes outboard? Upgraded these to among other things ease the pain of releasing the sheet.
Before:
After:
Bradley M. Davis - Hobie High Life YouTube Videos
2012 H16 (with 2018 Cayman Main) #115139
PostPosted: Sat Aug 02, 2014 8:55 am
That is correct, If you later decide to hook up a jib traveler kit, you would want the lock pins to the outside also.
79 H16 #46803
PostPosted: Sat Aug 02, 2014 11:25 am
Instead of a bowline knot, you may want to just run the end of the jib sheet through the lo-profile jib traveler's eye strap and then tie a figure 8 knot on the eye strap's backside.
This will allow you to pull your jib's clew plate further down.
Tim
84 H16
82 H16
87 H14T
Tortola Sails: 115222
Blue Prism Sails: 88863
Clearwater, FL
PostPosted: Sat Aug 02, 2014 11:29 am
Thanks for the tip on the figure 8 stopper. Will change before I launch today.
